oil leak
   / oil leak #1
Anonymous Poster
Epic Contributor
Hi to all i hope the new year starts better than mine, I was doing a little bit of slashing and noticed oil leaking from where the steering meets the top of the gear housing ,on a close look i noticed a small hole maybe a breather hole? Can someone tell why the oil is coming from it. Not sure what seals are in this area , any help please
Barry THE TRACTOR IS A L1500DT
   / oil leak #2
BarryS,
Not much info to go on. /w3tcompact/icons/frown.gif
Make an model would help,how about registering up. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
   / oil leak #3
you have water in your steering box..the only seal is onder the steering wheel.Kubota have this problem...take out the drain plug,get the water out.then put a grease fitting in the hole.and at least cover your steering wheel.
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
9202 (A50322)
9202 (A50322)
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
