Oil & Fuel Oil Leak on a 1971 165 MF
   / Oil Leak on a 1971 165 MF #1
mlanierjr
Greetings,
While repairing and adjusting my 165 over the past few weekends I noticed an oil leak where the tachometer cable enters the engine block. The cover plate has a hole in it above the the tach cable connection. It looks like it was drilled there at the factory. It only leaks at idle, I was adjusting the Multi-power which took a quite a while, and noticed that oil would drip, or spurt out. If you speed up the engine to 1100-1300 rpm's no leak. Is this normal? should I seal the hole ?
Thanks,
Michael
P.S. Any one have any front wheel weights they would like to sell?
   / Oil Leak on a 1971 165 MF #2
There is a seal behind that plate. Get the seal & plate gasket & it's an easy fix.
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
2011 VANGUARD 53x102 DRY VAN (A53426)
2011 VANGUARD...
2005 TerraGator 8104 (A53472)
2005 TerraGator...
(APPROX 72) UNUSED PALLET OF LANDHERO WHEEL STOPPE (A51248)
(APPROX 72) UNUSED...
UNUSED FUTURE ELECTRIC MASSAGE CHAIR (A51248)
UNUSED FUTURE...
More info coming soon! (A50323)
More info coming...
