Oil & Fuel Oil Leak on a 1971 165 MF
   / Oil Leak on a 1971 165 MF #1
mlanierjr
Greetings,
While repairing and adjusting my 165 over the past few weekends I noticed an oil leak where the tachometer cable enters the engine block. The cover plate has a hole in it above the the tach cable connection. It looks like it was drilled there at the factory. It only leaks at idle, I was adjusting the Multi-power which took a quite a while, and noticed that oil would drip, or spurt out. If you speed up the engine to 1100-1300 rpm's no leak. Is this normal? should I seal the hole ?
Thanks,
Michael
P.S. Any one have any front wheel weights they would like to sell?
   / Oil Leak on a 1971 165 MF #2
There is a seal behind that plate. Get the seal & plate gasket & it's an easy fix.
2025 INDUSTRIAS AMERICA FT510 5' X 10' HYD DUMP TL (A51247)
2025 INDUSTRIAS...
INDUSTRIAS AMERICA 435 HEADER CART (A51247)
INDUSTRIAS AMERICA...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
