Oil Leak in Tranny Cooler????
   / Oil Leak in Tranny Cooler???? #1
tmain
Carthage, NY
2003 TC35D
After working with my tc35d today I found a pretty bad oil leak in, I think, the tranny cooler (the smaller radiator in front of the engine radiator). My question is about how much do these cost and is there any way to fabricate a semi flexable mounting system for this cooler. I also couldn't find a part number for this cooler in my manual.
Thanks
   / Oil Leak in Tranny Cooler???? #2
Can you get it out and to a radiator shop to have them fix it? That might be cheaper.
   / Oil Leak in Tranny Cooler???? #3
The connector on the incoming side cracked on my TC35D - can't remeber what NH wanted for a new one. I took it out and had a local welder fix the crack - hasn't leaked since(3 years). It was simple to take out and do not think I lost any fluids. Hope this helps.
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
