Oil & Fuel Oil leak. I may have to split my TC24DA!
   / Oil leak. I may have to split my TC24DA! #1
JSUnlimited
Platinum Member
Ohio
New Holland
The other day I noticed a quarter sized area of oil under my TC24DA. It is dripping right from the rubber boot where the front universal joint is. On closer inspection it seems to be coming out of the hole on the bell housing area where it looks like the is a head of a cotter pin sticking out. So after looking at the service manual, it seems that I may have a rear main seal going on the engine. The oil level in the engine has dropped a good bit in the past couple of weeks.
Here is a pic from the service manual that I used windows paint to circle in red where the oil is coming from. Also here is a pic of the dipstick showing how low the oil has dropped in the past couple of weeks since I have noticed the leak.
I have about 540 hours on the clock.
I few more pics showing the area from which the oil is coming from.
So I guess I'll keep monitoring the oil level. If I do have to split, then I'll wait till early spring as I need the tractor to plow snow, haul firewood, etc.
TCBOOMER had a couple of post about splitting his TC24DA. You still here?
   / Oil leak. I may have to split my TC24DA! #4
For a drip the size of a quarter, don't think I would go to all the trouble of a split. I guess you never owned a Harley..... :p
   / Oil leak. I may have to split my TC24DA! #5
Or a british auto, or motorcycle.:D
Wish I had one!
   / Oil leak. I may have to split my TC24DA! #7
It only takes a little oil to make a big mess. Thats a pretty tiny mess. My two cents : I'd keep an eye on it, but i couldn't think about splitting the tractor over a drip that small. Of course....... my first tractor splitting didn't go so well.:eek:
   / Oil leak. I may have to split my TC24DA! #8
My panic level would be determined solely by the amount of warranty left, (if any).
A quarter sized spot is pretty small. But they aren't supposed to leak at all, and if you can get it fixed on someone else's dime, you should.
If it were my dime, it would have to get a whole lot worse before I'd split it. But if you have warranty left, that's hardly a response your dealer can afford to give you.
You guys make some ood points. I think I'll keep an eye on it for now....no sense in making a little problem a big one.
BTW, it out of warranty!
   / Oil leak. I may have to split my TC24DA! #10
People with Gen 1 Ford Lightnings would call that little spot "Marking its Territory".
2018 Ford Transit 250 (A57148)
2018 Ford Transit...
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
2833 (A58376)
2833 (A58376)
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
Giyi Horizontal Log Splitter (A57149)
Giyi Horizontal...
