Oil & Fuel Oil in Radiator
   / Oil in Radiator #1
akjohnston
I have a 8N ford tractor and I am getting oil in the radiator. Does any one know of what the problem may be. I am not getting water in the oil only oil in the radiator.
   / Oil in Radiator #2
If it has a oil cooler it's probably bad and would be the first thing to check.
edited to add: That would be a engine mounted oil cooler that cools the engine oil using the engines cooling system.
   / Oil in Radiator #3
No oil cooler on the N series tractors.. 8n was 1947 - 1952.. they were lucky to have a bypass 15% filtration system...
I replied to his post in the vintage section on what to check on that little 120ci flatty
Soundguy
2017 Peterbilt 348 Hood 7000 Grapple Truck (A55973)
2017 Peterbilt 348...
DIGGER DERRICK (A55973)
DIGGER DERRICK...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2007 STERLING TRUCK L9500 CHEMICAL TRANSPORT TRUCK (A58214)
2007 STERLING...
1R PLANTER (A52708)
1R PLANTER (A52708)
Freightliner Tender Truck - Adams Tender (A56435)
Freightliner...
