Oil/grease conversion data
   / Oil/grease conversion data #2
What are you using it for, Jay? :confused: I'm guessing that grease would have different, application-specific, additives than gear oil...
Neato chart, tho...
Neato chart, tho...
Maybe, but who cares - lube is lube. I'm putting it in the "transmission" (and I use that term loosely) for my 80's vintage Snapper LT16 lawn tractor. The transmission is a simple differential and reduction gear w/ chain-drive. Truth be told, I could put anything in there and it would work just fine. Using something with the same viscosity as specified is a bonus.
I'm using the tractor specifically for running a snowblower attachment to clear a driveway - I figured the gear oil would be better in the cold than grease.
JayC
   / Oil/grease conversion data #4
Good luck - your right about the lub qualities, but you will be lucky if that 85 wt oil stays in it. Snapper "00" grease is MUCH thicker than 85 wt oil.
I am not familiar with the Snapper model you have but the 85 wt oil will leak out of the Snapper models I have had experience with.
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
Informational Lot - Shipping (A55301)
Informational Lot...
2006 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A54607)
2006 FREIGHTLINER...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
