Oil/grease conversion data
   / Oil/grease conversion data #2
What are you using it for, Jay? :confused: I'm guessing that grease would have different, application-specific, additives than gear oil...
Neato chart, tho...
Neato chart, tho...
Maybe, but who cares - lube is lube. I'm putting it in the "transmission" (and I use that term loosely) for my 80's vintage Snapper LT16 lawn tractor. The transmission is a simple differential and reduction gear w/ chain-drive. Truth be told, I could put anything in there and it would work just fine. Using something with the same viscosity as specified is a bonus.
I'm using the tractor specifically for running a snowblower attachment to clear a driveway - I figured the gear oil would be better in the cold than grease.
JayC
   / Oil/grease conversion data #4
Good luck - your right about the lub qualities, but you will be lucky if that 85 wt oil stays in it. Snapper "00" grease is MUCH thicker than 85 wt oil.
I am not familiar with the Snapper model you have but the 85 wt oil will leak out of the Snapper models I have had experience with.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
Carnival Ticket Booth (A51691)
Carnival Ticket...
