Oil for Yanmar F 200
   / Oil for Yanmar F 200 #1
mario.skocic
GRENADA W.I.
Yanmar F 200
Good morning everyone,
On my second hand YANMAR F 200 is not enough oil in the place marked with # 1 (please see attached photo).
Existing oil is red. The same oil goes through the filter (CAPA, CP145VL-35) on the hydraulic pump, which is located on the engine.
1 / What kind of oil should be used?
2 / Do I have to complement the oil or is it better to change all the oil?
Thank you for your cooperation and assistance.
Mario
   / Oil for Yanmar F 200 #2
over here where i live. I'd use a good UTF fluid .. many are dyed red.. like HYtran.. etc.
i'm not familiar with your tractor enough to say if it specs an ATF type fluid or not ( also commonly dyed red ).
if it was a straight gear machine.. i think i'd opt for a utf.
if it's a lil low.. mixing is usually fine.. if it's way low.. i'd change it.
hopefully someone with your machine type will come along and quote the spec out of the book.
good luck and welcome to TBN
Thank you Soundguy,
You're right. I found in other sources also UTF and Hytran.
So I think that's it.
Regards Mario
   / Oil for Yanmar F 200 #4
good luck with your machine.
   / Oil for Yanmar F 200 #5
Don't know about your newer yanmar,but on older ones like mine, some owners have used ATF which is red. while others like me, use hyd fluid JD 303 specs
40' shipping container (A52377)
40' shipping...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2012 KENWORTH T800 (A53843)
2012 KENWORTH T800...
2004 Cherokee Lite 28A 30FT T/A Travel Trailer (A51694)
2004 Cherokee Lite...
PALLETS OF HEAVYEQUIPMENT (A53843)
PALLETS OF...
2006 Hummer H3 4x4 SUV (A51694)
2006 Hummer H3 4x4...
