Backhoe Oil for backhoe ?
   / Oil for backhoe ? #1
wanasrx
Bronze Member
NY
Kioti 3054
I have a kb80 hoe, manual says to use 10w40 w/"sd" rating, can I use rotella t 15w40?
Rich
   / Oil for backhoe ? #2
What is a kb80?
Do you mean a kioti kb2385.
   / Oil for backhoe ?
It's a Kioti subframe mounted Backhoe. Model KB80
   / Oil for backhoe ? #4
</font><font color="blue" class="small">( It's a Kioti subframe mounted Backhoe. Model KB80 )</font>
Never heard of it.
Also don't recall ever seeing it listed on the Kioti website or sales fliers
   / Oil for backhoe ? #5
Wallace - Its an older model Kioti hoe... I acutally have a part manual for it.... Its a very old hoe...
wanasrx - I wouldn't waste the money for Rotella-T just use an engine oil 10w40. Our skid loaders use an engine 10w-30 for its hyd oil.
   / Oil for backhoe ?
Thanks Jon
Rich(wanasrx)
   / Oil for backhoe ? #7
I would use either the motor oil or use the same hydro oil you use in your tractor.
That backhoe is definitely old.
   / Oil for backhoe ?
What does everyone use for hyd. oil?
How old do you think it is?(she still seems to work good) The tractor can't be older than a 93' , yes?
   / Oil for backhoe ? #9
Give a serial # and we can see if Kioti has it on file.
   / Oil for backhoe ? #10
If you BH has motor oil in it now I would keep using a motor oil in it.
As far as the tractor we use a high quality UTF "Universal Tractor Fluid" that is rated for both hyd and transmissions. We use Allied brand fluids here only because we are a dealer for them. There are alot of good brands out there though.
What model tractor and loader do you have?
2020 Kenworth T880 Tandem Axle Day Cab Road Tractor (A47384)
2020 Kenworth T880...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
12' UTILITY SERVICE TRUCK BODY (A51244)
12' UTILITY...
2008 INTERNATIONAL DURASTAR 4300M7 SBA 4X2 DUMP TR (A51243)
2008 INTERNATIONAL...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
