Oil & Fuel Oil foaming in trans, Normal?
/ Oil foaming in trans, Normal? #1
Ralyjohn
Fort Edward,N.Y.
2017 Kubota BX23s
The oil in the trans is foaming when running tractor, doesn't seem to cause any effects to operation of FEL or BH. Only thing I hear is when moving BH side to side there is a sort of gushing sound of the oil going through the valve. Is this normal with the BX24 Hydro trans? It will fill the air space in the trans right up to the check dipstick. Seems to be doing this since first oil change at 50 hrs, at least that is when I noticed it for the first time. Can't find any leaks of oil any where that would indicate air being pulled in from any hyd. system connection. I don't run it hard, usually about 2200-2500 rpm.
/ Oil foaming in trans, Normal? #2
That much foam does not sound normal. Does this only happen when using the BH or does it happen all the time?
Happens all the time, weather BH or FEL are on or not, for just mowing. Tractor has 500+ hrs on it, happens with SUDT or UDT fluid. Dealer told me they only use SUDT in warranty repairs.
/ Oil foaming in trans, Normal? #4
My BX 1850 does not do this but it does not have the BH attachment either. Does the tranny seem to get hot or make any excessive noise?
Tranny is not noisy, had it to dealer to be checked, I thought the trans was getting too hot, would steam water off if washed when hot, but normal temp is 100 deg above ambient according to dealer. I checked it one time on 80 deg day and it was around 170 deg with digital thermocouple for my DMM.
/ Oil foaming in trans, Normal? #6
Can you try a simple test?
I don't care which function you use but can you operate either the MM mower raise until it stops or one of the FEL controls until the cylinder stop moving. Do you here the relief valve at this point? Does the engine labor any more or change sound from when the function is moving Vs stopped?
A stuck or leaking Relief valve can cause foaming and will also cause excessive heat.
I can hear the relief valve working if I hold the up handle for the MMM. The RPM goes up when released. I requested a parts diagram for the trans from Messicks to try to see where the relief valve is so I can check for it being stuck open or such. The BX24's don't have any hyd pressure for the attachments till the RPM is above 1600, I understand that that has been changed on the newer BX25/26's that they will have HYD pressure at idle for the FEL and BH.
/ Oil foaming in trans, Normal? #8
Mine will be a little foamy when I check it after being used, but not very much, not enough that it has alarmed me. Could a slight air leak cause this?
/ Oil foaming in trans, Normal? #9
I would make sure that the vent is in good working order.
/ Oil foaming in trans, Normal? #10
When was the oil last changed?
Does it sit outside. I would wonder about water in the oil. Water will cause hydraulic oil to foam.
/ Oil foaming in trans, Normal? #11
ditto.
water in the oil. was told for another issue, water collects in the bottom. and oil on top. so try letting tractor set for a day or so and not being ran. and then remove the drain plug in the very bottom. and let some oil run out. put drain plug back in, and top off the oil.
Last oil change in trans was at 300 hrs, due for change in about 70 hrs. It does not sit outside, always garaged, and FEL and BH if not on are under cover. No cloudiness in oil.
/ Oil foaming in trans, Normal? #13
ditto.
Because hydraulic oil emulsify water that will not work. If water has contaminated the system then the only remedy is to drain and replace.
/ Oil foaming in trans, Normal? #14
I would check the vent. It may be plugged.
/ Oil foaming in trans, Normal? #15
Mine a lot of times has some foam near the top...usually not a whole bunch...
/ Oil foaming in trans, Normal? #16
I would carefully inspect the piping from the filter screen to the hydraulic pump. Air can go where oil cannot, and you could be drawing in air through that inlet hose.
If a man pulls he lower plug and is rewarded with water but not emulsified oil, he'd have his answer. I doubt a man would repeat the practice with no reward.
I have seen water emulsified with oil to the point that a centrifuge failed to separate it, and other times I have seen water only at the bottom of the tank. I think it depends on the oil, and the speed of the water insult, and the overall size of the insult. I think water encroachment through tank breathing is less likely to be emulsified than water entry from direct means, such as rain.
Also arrangement of the apparatus seems to matter. If there is no place in the bottom for water to be, water will be entrained pretty quickly.
The op says his oil is clear, so I don't suspect water as his issue.
2010 FREIGHTLINER M2 BUCKET TRUCK (A65643)
2010 FREIGHTLINER...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
2006 Ford E-350 Passenger Van (A64194)
2006 Ford E-350...
Concrete Mixer (A62613)
Concrete Mixer...
Wolverine 84" Quick Attach Snow Push (A66285)
Wolverine 84"...
