Oil & Fuel Oil Filters
/ Oil Filters #1
Neat 1500
Platinum Member
Queensland,Australia
Only a YM14 MkII
I am looking for an oil filter for the 1500 as i want to do an oil change but am having difficulty locating one for it, it currently has a Sakura C-1605 on it but am unable to locate one here in Australia.I did find a reference for it but it was for a Honda passenger car so i suspect it is not a proper diesel filter.I would like to try and source them here before i look elsewhere(Read:USA) does anyone know of a filter to suit a 2TR-15 of another brand i may be able to find here? we have Ryco,Baldwin,Fram,Cooper,Donaldson and Fleetguard to name a few.Do you have any of these over there?
/ Oil Filters #2
We see that question here from time to time. After reading replies for some five years, here's my opinion I posted a while back:
Search here on 1064 and 1334 (both in the same search) to see previous discussions. Wix shows 51064 (5 just means 'Wix') for YM240, US version of YM2000. It's a common filter. If 1064 fits YM2000 then it should fit nearly all the smaller YM's as well.
1334 is similar, same interface (threads and gasket), has a larger enclosure which might mean better cooling or longer use before it plugs up. 1334 is near-universal on all Hondas so you should be able to find it anywhere. Some of the aftermarket Yanmar parts dealers call their 'unique custom filter for Yanmar' a 1334 for some reason.
There are some applications (YM2000B etc) where the 1334 is too big to fit the available space, only the little 1064 will fit.
1064 has a higher relief vave pressure. If I remember, 12 psi compared to 8 on the 1334. (It's in one of the posts that the search will bring up). I don't know how this is significant.
Me, I use the NAPA Gold 1064. After you open the box, 'Wix' is stamped on the filter cannister. I think the lesser volume is an advantage, it reduces the time before full oil pressure is reached on a cold start. (And I spin it with compresssion released to get some oil pressure, too). That's just opinion, I'm sure others have other opinions.
/ Oil Filters #3
I get them from my dealer by the case.. Last time I checked .. Dealer was cheaper than the wix.. Don't know if the wix is a better filter or not
/ Oil Filters #4
Balwin B227
Danny
/ Oil Filters
I spoke to a Baldwin dealer today and he said a B1421 Baldwin will fit it OK. it has a 14 PSI bypass valve in it, in saying that what is the rough oil pressure of a 2TR-15?? as i can get the same filter with a 6 PSI or 18 PSI valved filter, just trying to work out what is going to be best.
/ Oil Filters #6
The YM1500 came with Yanmar part # 124450-35100 which = Balwin B179. Yanmar changed the part# to 119660-35150 which = Balwin B227. This is on Balwin's cross chart. There are hundreds of filters that ( will fit ).
Danny
/ Oil Filters
Danny
Thanks Danny, i will pay him another visit with those numbers and see what fits the bill best of the 3 numbers i now have.
/ Oil Filters
I have bought myself a couple of Baldwin B227 filters, they have a 20 PSI valve in them. the B179s that Danny was refering to are the same filter but only have a 8 PSI valve in them. the B1421 i had gotten earlier would fit also, same width and thread but longer in length and 14 PSI valve. Talk about a drama for a bloody oil filter!! Thanks to those whom had some input.
2016 KENWORTH T880 (A67714)
2016 KENWORTH T880...
2002 PETERBILT 330 VACUUM BOBTAIL (A67714)
2002 PETERBILT 330...
2019 Toyota Mirai Sedan (A66738)
2019 Toyota Mirai...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
porta potty (A68842)
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
