Oil & Fuel OIl Filter
   / OIl Filter #1
jethroish
Scottsburg, IN
RK55S, CC EX3200
Doing my first oil change on EX3200 today. Did a filter look up on Wix then crossed it over to a Bosch (O'Reilly's had Bosch on sale). Came up with Bosch 3312 oil filter. Anyone know if this is correct? When I change it, I will do a close inspection. Oddly, this filter is used for 1982? Hondas.
   / OIl Filter #2
Its pretty close, the thread matches up. Here's some specs, I found more information on the Wix/Napa Filter:
BOSCH Part # 3312
Outside Diameter: 3.15"
Thread M20X1.5;
Wix 51334 & Napa 1334 Oil Filter
Principal Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-09), Hyundai (89-10), Isuzu (85-04), Kia (01-10), Mercury (87-91), Mitsubishi (89-98), Subaru (87-10) Atlas-Copco, Case, John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel, Other
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
(This information from Wix Filters & NapaGold Filters: FleetFilter Secure Online Store)
   / OIl Filter
Thanks for the specs. The rubber gasket matched up. The original filter had 5 holes around the top, the bosch had ( I think it was) 7. Aside from that, the Bosch is about 1/4 inch shorter.
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
HEADACHE RACK (A50854)
2005 GROVE RT700E ROUGH TERRAIN CRANE (A50854)
2005 GROVE RT700E...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
