oil filter won't come off HPX 4x4 diesel:help
   / oil filter won't come off HPX 4x4 diesel:help #1
iowaken
Morrison Illinois
Gator HPX 4x4 Diesel, JD 50, JD 2305, Century 2028
Help: I can't get the oil filter off my HPX 4x4 Diesel. Won't budge or even wiggle? Anyone know any tricks? Tries from above and below.
   / oil filter won't come off HPX 4x4 diesel:help #2
are you using a filter wrench? If not get one. If you are hammer a screwdriver into the side and twist.
   / oil filter won't come off HPX 4x4 diesel:help #3
I've had to drive a screw driver through the side of a filter on a Ranger to get it off. Don't know why they put them on that tight.
   / oil filter won't come off HPX 4x4 diesel:help #4
Sometimes a rubber strap wrench works real well for stubborn filters. Only problem I've had is sometimes I didn't have enough room to swing it. I like the strap wrench for it's versatility - a filter wrench is really only useful for filters, but a strap wrench is great for anything you want to put a death grip on, round or not. It's also great for putting said death grip on something that you don't want to damage in the process. I used mine yeaterday to remove a stubborn plastic coolant reservoir cap.
-Jim
   / oil filter won't come off HPX 4x4 diesel:help #5
I've had a few factory tightened oil filters that wouldn't budge with a filter wrench so I resorted to the screwdriver trick.
Get the largest phillips screw driver you can fit in the area and hammer it through the side of the filter at the END of the filter so you don't hit the "bolt" on the filter housing that the filter screws into. Twist and off it comes, there will be oil dripping out of where ever the screw driver goes in and out so have some rags ready.
   / oil filter won't come off HPX 4x4 diesel:help #6
you could hammer a nail into the bottom of the filter , and let it drain, before driving the screwdriver thru and save yourself a mess possibly. zman :cool:
   / oil filter won't come off HPX 4x4 diesel:help #7
Get the metal cup-style filter socket that fits over the end of the filter. You'll need to tap it on the filter and use a 3/8 rachet to turn it. Not a lot of room to work. It'll be hard to remove the first time. I've actually used a short pry bar to keep it tight on the filter. Just be sure to lube the gasket on the new filter and don't over tighten.
   / oil filter won't come off HPX 4x4 diesel:help #8
I always warm up the motor prior to removing the filter. This makes it much easier. Also, as others said, lube the new filter gasket prior to installation.
If you poked a hole in the filter, none of this helps though.
Snap-on has a racheting filter wrench that removes almost any stubborn filter (BluePoint: apx $35).
Thanks to you all! we finally got it off with our neighbor's chain wrench. Screwdriver trick didn't do it at all. We made sure the new filter was hand tightened and the gasket oiled.
   / oil filter won't come off HPX 4x4 diesel:help #10
Guess which one of these guys installs filters for his day job?:laughing:
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
(2) Sumitomo 11.00 R22 Tires (A51573)
(2) Sumitomo 11.00...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
MONOSEM NG-3 LOT NUMBER 267 (A53084)
MONOSEM NG-3 LOT...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
