Oil filter suggestions
   / Oil filter suggestions #31
It's been little over two years, sure the OP got the oil/hydro filter off without issue. Anyway, used to use large channel locks, then I picked up a oil filter wrench from NAPA. Pretty pricy, it will be the last one I will ever have to buy. Works on small to large filters. Can also get different other brands which should work fine online like Amazon.
   / Oil filter suggestions #32
Life gets interesting when the filter itself starts to deform due to all the torque you are putting on the filter canister.
   / Oil filter suggestions #33
If it came down to it, and you could do so without risk of slipping or chewing up the block or whatnot, use a big flat-blade screwdriver as a punch on the ring edge of the filter (where the inner and outer shell portions are mated together) and apply some hammer blows. That'll produce torque nearest where the binding is happening. With filter wrenches and such you're applying torque away from the sticking point, through the outer, flimsy shell, which sucks up the energy by crushing and twisting. I've not had to resort to this (just now thought about this approach after reading through this thread), but will look to apply it at the next opportunity (which isn't likely going to happen to anything I've already worked on, so it'll have to be something newly acquired, and nothing's on the horizon- I'll probably never have the ability to test this theory!).
One of the great things about my VW TDIs is that they use cartridge oil filters. Easy to remove cap. And from the TOP of the engine. I do top-side oils changes (using an oil extractor). No easier oil change to be had!
   / Oil filter suggestions #35
I have a lisle 60200 heavy duty strap wrench. Worked great for the filters on the Kioti as well as other very stuck filters. I used it with a 18 inch long half inch drive ratchet.
   / Oil filter suggestions #36
Amazon has several pro diesel mech & equipment pros saying they like this nylon strap filter tool.
Hose Reel (A53424)
Hose Reel (A53424)
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
Year: 2011 Make: Peterbilt Model: 365 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A55852)
Year: 2011 Make...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A57024)
2021 John Deere...
2016 Hyundai Tucson (A53424)
2016 Hyundai...
