Oil & Fuel Oil filter "part cross-over"
   / Oil filter "part cross-over" #13
Hey WV,
Like you its always when the dealer is closed or when I get the bug to do an oil change on my truck and its after hours, so...
For the first change I always by 2 filters and twice the oil...Expensive the first time, but now I have a oil change kit ready for me...
I mkae a habit of restocking, ASAP ie the next day or so, other wise I'm back to square one....
I always end up doing this stuff spur of the moment, nothing on TV so I grab a "cold one" and head to the garage...
Just a thought....
   / Oil filter "part cross-over" #15
I don't work for Kubota.
I'm not a dealer.
But I would like to share the following with you.
My 3030 whined extremely loud with NAPA filters. Replaced with Kubota filters and the wine went away.
I'm afraid that the NAPA filters provided "Superior" (lower micron rating) but at the cost that it was more restrictive.
Since they were more restrictive, I believe that they were causing cavitation in the pump causing it to wine at low RPMs
   / Oil filter "part cross-over" #16
The ONLY other filter I would consider using is a fleetguard. These are really made for tractors and off road equipment. The differences between filters can be staggering when you see them cut appart. Fleetguard OEM's most of the filters for NH, Case, Deere, etc. However, often they are more expensive to buy the fleetguard branded filter than it is to just buy from the private label.
   / Oil filter "part cross-over" #17
Fleetguardfilterstore.com, Your #1 Source for Fleetguard Filters has two filters that will work for this application at about half the price:
LF3707 -- $5.55
LF3462 -- $5.71
if you by a case you get 5% more off the total.
if you have a good friend at a ford dealer, they can get them cheaper
many fords have oem fleetguard filters (f350 450 and up)
when i got my dodge diesel my friend got me oil filters for 3.00 ea by the case
but that was 20 years ago
the big trucks go a million miles and only use fleetguard
you cant go wrong using fleetguard
   / Oil filter "part cross-over" #18
Auto zone cross ref FRAM PH3593A at $3.99
   / Oil filter "part cross-over" #20
I will "second" the recommendation for Filter1. Filter1 Wix heavy duty engine, oil, automotive, truck, and tractor filers.
I have been buying from them for about 4 or 5 years. I set up an account and just order for myself, family, friends, and coworkers. I have ordered filters for everythng from dozers and log skidders to marine engines to motorcycles and gensets. Not to mention filters for my Kubota B7100D. I haven't ordered any for my new B3200 as of yet as it still only has about 10 hours on it!
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A57880)
2002 MANAC 48'...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
RAVEN 100 GALLON FIBERGLASS TANK (A57192)
RAVEN 100 GALLON...
CATERPILLAR HM416 MULCHING HEAD (A52707)
CATERPILLAR HM416...
UNUSED FUTURE 350 HYD EXCAVATOR BREAKER HAMMER (A57193)
UNUSED FUTURE 350...
