Oil Filter numbers
/ Oil Filter numbers #1
UWAdventurer
Does any one have alternative oil filter numbers for the L3400 and the BX1860 tractors, such as NAPA, Fram, WIX, etc. If you have the stock Kubota filter numbers I could try to cross reference them also.
Thanks all.
/ Oil Filter numbers #4
I use a fram PH8A equivellent on my L3400. Thread and o-ring sizes are the same, but it is a bigger filter. (quart sized). And I have to leave the bottom screw out of the plastic guard.
The PH16 is also the same, only the pint-sized version.
You can cross those two #'s to any brand you wish.
I perfer the fram XG series of filters
2018 Dodge Charger (A61574)
2018 Dodge Charger...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2015 Ford E-350 Shuttle Bus (A61573)
2015 Ford E-350...
PALLET OF TRAILER TAIL LIGHT (A64280)
PALLET OF TRAILER...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2012 Generac QT04854 Anax Quiet Source 58kW Natural Gas Generator (A61572)
2012 Generac...
