Oil & Fuel oil filter number
   / oil filter number #1
rottonrob
North Idaho
tym 233HST
Hello,
Just bought a used t233hst and need to know the napa or wix or some common oil filter number...Thanks
   / oil filter number #2
Rob,
I just googled the TYM part number and oil filter and came up with some name brand alternatives for my T353HST. Jordan Sales in Post Falls has always been a good source of info for me. Buy a replacement from them and ask them about equivalent/cheaper filters.
   / oil filter number
Thanks,
I crossed at NAPA and came up with a 1358 filter...
   / oil filter number #4
i have a 353HST also......what did you find ?
my local TYM dealer went out of business 3 years ago, so i have ordered from dealers in other states, but Local would Be great.
also, what engine oil did you use for your 353 ??
thanks
bob
   / oil filter number #5
thanks
bob
Bob,
Here is the info I found for my 353;
TYM FILTERS
OIL
Donaldson – P502067 Original Part ($ 15.41) Dealer
• Fleetguard – LF 3925
• Baldwin - B 1400
• Fram – PH 6607 or 6017A
• WIX – 57040 or 51365
Hydraulic
Donaldson – P169078 Original Part ($43.00) Dealer
• Fleetguard – HF 35006
• Baldwin – BT 8416
• Fram – P 7537
• Wix – 51586
AIR
Donaldson – Outer - P8121575
Inner - P822858
I will check on what oil I used and get back to you.
   / oil filter number #6
THANKS---I FOUND THIS
LUBE SPIN-ON FULL FLOW
Primary Application NISSAN, MAZDA, MITSUBISHI
Alternative parts
Bar Code 74233010989
Sizes C - Length: MM 65
B - Thread Size: N/A M20 x 1.5
D - Gasket OD: MM 65
E - Gasket ID: MM 56
Efficiency Beta 2: Micron 20
Relief Valve Setting: Bar 0.80-1.00
Weight: Kgs 0.20
Cube: Cubic Meters 0.00
A - OD: MM 68
Cross Reference AC: PF1237, PF2112, PF2135 - ALCO: SP1001, SP1002 - AMC: L6607, MO6607, OC14090, OC15180, OC16090, OF2021, SFO4621, VO54, Y1193053150, Y11930535150 - AMS/OIL: EAO12, SDF13 - ASAHI: 11K, 526K, FO011A, MO256 - ATLAS: M33 - BALDWIN: B1400 - BIG A: 92358, 92365 - BLACKROCK: 1090007 - BOBCAT-MELROE: 6671057 - BOMAG: 5740096 - BOSCH: 3300, 72180, 72182 - CARQUEST: 85365 - CHAMP: PH2876 - CHAMPION LABORATORIES: PH2868, PH2876, PH7015, PH7028 - CHARLES MACHINE: 194691, 452410 - CLEAN: DO854, PO6607 - COOPERS: Z1039 - CROSLAND: 2151 - DANIEL DOYEN: DOF4901 - DEUSCH: D371 - EXMAN: L6607, MO6607, OC14090, OC15180, OC16090, OF2021, SFO4621, VO54, Y1193053150, Y11930535150 - FEDERAL MOTORS: FMS1809, FMS2046 - FIAAM: FT5406 - FIRESTONE: TF4622 - FLEETGUARD: LF3692, LF3925 - FLEETRITE: LFR83692 - FORD: E9GZ6731A - FRAM: DG6607, PF9715, PH2876, PH4998, PH6017, PH6017A, PH6607, PH9715, TG6607 - FSA: FO1033 - GM: 25014422, 25171946 - GOODYEAR: L4622 - GREYFRIARS: 9034S - GROUP 7: V4612, V4622 - GUD: Z222 - HASTINGS: LF113 - HINO: 156072110 - HONDA: 15400PFB004, 15400PH3004, 15400PJ7005, 15400PJ7015, 15410MCJ000, 15410MCJ003, 15410MM9013, 15410MM9405 - HYUNDAI: 263002Y500 - INGERSOLL RAND: 85426849 - JACOBSEN TEXTRON: 5002644 - JOHN DEERE: M806418 - KAWASAKI: 160971063, 160971072 - KIA: 2630002500, 263002Y500, B63114302, FE3R14302, OFE3R14302 - KNECHT: OC195 - KOBELCO: 11930535150 - KOMATSU: 11930535150, 1930535151, YM11930535150 - KRALINATOR: L265, L266, L358 - KUBOTA: 1585332430, 1585399170, 1585399179, HH15032430 - LEE ENGINEERING: LF2868 - LONG: A0653039 - LUBER-FINER: PH2876, PH7028 - MANN & HUMMEL: W671, W6780 - MAZDA: ADM52106E, B63014302, B63114302, B65114302, B6Y114302, B6Y114302A, B6Y123302, B6Y214302, B6YL14302, F2Y014302 - MICROPORE: T600 - MITSUBISHI: 30A4000200, 30A4000201, 30A4000202, MD134593, MD134953 - MOBIL OIL: MO4612, MO4622 - MOPAR: F0PH2868, F0PH2876 - MOTORCRAFT: FL816 - NAPA: 1365, 21365 - NIPPON: J1317004, MTW61, T59 - NISSAN: 1520865F00, 1520865F01, 15208HC010, 15208KA000, 15208KA010 - PENNZOIL: PZ37 - PERKINS GREAT LAKES: 102619 - PHILLIPS 66: PO1357, PO1365, WO1365 - POLARIS: 3084963 - POWER-FLO: SL14612, SL14622 - PRO-TEC: 168 - PURFLUX: LS892 - PUROLATOR: L14612, L14622, ML16817, ML16819, PER4622, PL14612, PL14622 - QUAKER STATE: QS14612, QS6607 - REPLACED BY: P550641 - SAAB: 32005769 - SAKURA: C1809, C18093, C18094, C18096 - SDMO: 330560538 - SHELL: S58, SH531, SH538 - SOFIMA: S3258R - STP: S6607 - SUBARU: 15208AA024, 15208AA080, 15208AA09A, 15208AA100, 15208KA000, 15208KA010 - SUNOCO: O37 - SURE FILTER: SFO4612 - TEHO: 4189 - TEXACO: HSO134, TFC531 - TORO: 934295 - TOYOTA: 1560187703 - UFI: 092325840, 2325800, 2325840 - UNION 76: PF1365 - UNION CITY BODY: C431, C830 - UNIVERSAL: C431, C830 - VIC: C806, C901 - VMC: LF502067 - WARNER & SWASEY: PH2868, PH2876, PH7015, WPH2876, WPH7015, WPH7028 - WIPAC: CA151, CA168 - WIX: 51365 - WOODGATE: WGL9056, WGL9197 - YAMAHA: 3FV1344000, 5GH1344000 - YANMAR: 11930535150
Truck Wheel Fenders (A51692)
Truck Wheel...
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
CAT Skid Steer (A50322)
CAT Skid Steer...
2016 CHEVROLET 2500 TRUCK (A51247)
2016 CHEVROLET...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2019 John Deere 5090R Tractor (A52384)
2019 John Deere...
