oil filter for LS MT357
   / oil filter for LS MT357 #1
Hammerhead Ted
Temecula, CA
2017 Kubota L2501 and 2021 LS MT3 57 Power Shuttle Cab
I recently bought a new LS MT357 and getting the oil filter off was very difficult, because it was so short. Can anyone recommend a longer filter that fits?
   / oil filter for LS MT357 #2
Not the answer you’re looking for, but a strap-type filter wrench will work. That’s how I got the filter off for my 50 hour service. The strap barely fit around the end, but was on well enough.
better yet, see if you can get a socket for it. (Below)
If you put a little oil on the rubber gasket on the filter, and follow recommendation to make it hand-tight plus a turn, you will never run into this issue again.
I would doubt you will get a cross reference part that is a vastly different size, so you might be gambling on a proper fit. Not worth the chance of engine issues to me.
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
POLY BARREL & WELL TANK (A58374)
POLY BARREL & WELL...
2019 Ford F250 (A55973)
2019 Ford F250...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2019 Deere 35G (A53317)
2019 Deere 35G...
