oil filter canister
/ oil filter canister #1
ken ontario
1962 mf50
Hi all!! New on here. I just bought a 1970 MF135 with a 3 cyl Perkins gas engine and I thought I'd change the oil before I used it too much. Anyway to my surprise, I found the oil filter was installed wrong. The spring was upside down and stuck inside the filter. I can't find a diagram which shows the correct way to install the filter inside the canister. I think I figured it out but not completely sure of myself. I believe the previous owner didn't install a washer on top of the spring. Any help would be appreciated. Thank you in advance.
And there's a metal washer with a rubber gasket on it at the bottom of the canister.
/ oil filter canister #3
`i had the earlier TO35 (Standard) but can't answer your question
i'd suggest to post your question in the Vintage Massey forum as well
regards,
Which way does the spring go? Cone up or cone down and shouldn't there be a washer on top of the spring to make the filter spring loaded when installing? I am going to switch to the conversion kit later but it takes so long for parts to be delivered up.
Found a parts breakdown at AGCO. Thx everyone.
Morning again. The oil pressure idiot gauge showed high before I changed the oil and it still shows high after putting the filter in the right way and changing the oil. Does any one know what the spring loaded ball in the oil filter head does? It's not seized. Is this the pressure relief ball? Do I need to remove the pan to get at the oil pump? I'm going to swap out the oil pressure gauge first before taking the pan off. Has anybody done a flush on the oil system and does it work? P.S. I've ordered the spin-on conversion kit. Thank you.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
John Deere XUV825E (A61307)
John Deere XUV825E...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2001 Kubota L3010 (A64126)
2001 Kubota L3010...
John Deere 1720 (A64126)
John Deere 1720...
