Oil Filter Campatibility Question
/ Oil Filter Campatibility Question #1
scsims
Central, KY
Mahindra 5525
I have a 5525 and the dealer sent me the wrong oil filter. I believe its for a 7520. Can I use this filter, it looks the same just longer?
/ Oil Filter Campatibility Question #2
I would check with the dealer that sent it to you.
Ken
/ Oil Filter Campatibility Question #3
If your tractor is a Tier 3 that is the filter Mahindra recommends, if is Tier 2 the shorter filter is the correct one. IMO I don't think it will cause any ill effects to use the longer filter on the Tier 2 engine.
Dave
How do I know if it's tier II or III? It's a 2009 4 cylinder deisel 5525 if that helps.
/ Oil Filter Campatibility Question #5
scsims,
If it is a 4 cylinder engine with no turbo, it is Tier II. If it is a 3 cylinder turbocharged, it is Tier III. The 5525 is one of very few Mahindras that have multiple engine filter requirements depending on build date. Your tractor should use p/n 000020316E05 or 006008549C1 for an oil filter. Tier 3 uses 006008803F1 or 006002508F1. Unfortunately, I am not sure if the Tier III filter will work properly on the Tier II engine. Just my $.02
PORTA POTTY (A68842)
2013 FREIGHTLINER CORONADO 122 SD (A67714)
2013 FREIGHTLINER...
2016 Nissan Titan XD Crew Cab Pickup Truck (A66736)
2016 Nissan Titan...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
2012 ATLAS COPCO  AIR COMPRESSOR XAS 375 (INOPERABLE) (A68842)
2012 ATLAS COPCO...
