Oil Filter Campatibility Question
   / Oil Filter Campatibility Question #1
scsims
Central, KY
Mahindra 5525
I have a 5525 and the dealer sent me the wrong oil filter. I believe its for a 7520. Can I use this filter, it looks the same just longer?
   / Oil Filter Campatibility Question #2
I would check with the dealer that sent it to you.
Ken
   / Oil Filter Campatibility Question #3
If your tractor is a Tier 3 that is the filter Mahindra recommends, if is Tier 2 the shorter filter is the correct one. IMO I don't think it will cause any ill effects to use the longer filter on the Tier 2 engine.
Dave
How do I know if it's tier II or III? It's a 2009 4 cylinder deisel 5525 if that helps.
   / Oil Filter Campatibility Question #5
scsims,
If it is a 4 cylinder engine with no turbo, it is Tier II. If it is a 3 cylinder turbocharged, it is Tier III. The 5525 is one of very few Mahindras that have multiple engine filter requirements depending on build date. Your tractor should use p/n 000020316E05 or 006008549C1 for an oil filter. Tier 3 uses 006008803F1 or 006002508F1. Unfortunately, I am not sure if the Tier III filter will work properly on the Tier II engine. Just my $.02
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2011 Dodge Ram 3500HD (A50120)
2011 Dodge Ram...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
