Oil Filter and oil
   / Oil Filter and oil #1
Bob_Bainbridge
Platinum Member
NE Ohio
I changed the engine oil and filter on my new Cub Cadet 3235 today as recommended at 10 hours first time. I replaced the original filter, which is 2-5/8 long with a Fram PH3614 filter that I use on our 2 Saturns. It is the same diameter and thread but is 3-3/8 long. Does anyone see a problem with this? Also is the Hy-Tran oil Iused in my old CC 1450 suitable for the hyrdrostatic drive on the new tractor? Thanks, Bob
   / Oil Filter and oil #2
I don't believe I'd use a filter that was not recommended, or was not a direct crossover. The internal components and workings may not be compatable with the motor even though it screws on alright.
Your new tractor has a warranty. If the dealer determines an engine failure due to improper lubrication, your out. New engine about 1500.
Same with your hyd. oil and filter. Use what's recommended or it may cost you alot of money.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
1998 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A52707)
1998 BOMAG...
2022 Kuhn Axis 50.2 H-EMC-W Fertilizer Spreader (A53485)
2022 Kuhn Axis...
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
