Oil filter adapter.
/ Oil filter adapter. #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Bought one of the $40 ones and it cracked. No luck returning it and the thread I posted about that whole story got deleted.
Anyway, I decided to make one from solid steel instead of the cast.
/ Oil filter adapter. #4
What's your goal, curious.
Adding a filter?
Thanks, Fred
Its an adapter to use a normal spin on filter instead of the cartridge type with the separate outer housing
/ Oil filter adapter. #6
Nice job LD1. Did you do the machine work?
Yep.
Forgot to post this....its what it started like.
The center threaded adapter. Threads into the existing block threads and accepts the spin on filter on the other end.
The plate I made just directs the oil where it needs to go.
NEW HOLLAND 6' SICKLE BAR MOWER (A64280)
NEW HOLLAND 6'...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2025 Miscellaneous Mini Excavator Attachments (A61572)
2025 Miscellaneous...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
20ft 4-Door Shipping Container with Shelving (A61572)
20ft 4-Door...
