oil filter 1610TS
/ oil filter 1610TS #1
Rambo
What is the correct oil filter for a iseki 1610TS? I heard that using the wrong oil filter could cause problems. In which I have oil coming from oil cap. I changed the oil and notice after running for about 5 min. it started coming out of oil cap. I don't know if this would cause it or not.
Thanks,
Rambo
NC
/ oil filter 1610TS #2
If oil is coming out the fill opening it could be due to excessive blowby due bad rings.
/ oil filter 1610TS #3
Oil is coming out the breather cap because the rockers and rocker shaft are worn. I have the same tractor, had same problem. Seems to be somewhat common with this Isuzu motor. I installed new rings first but that didn't help. The only way for oil to get back down to the pan in these Isuzu motors is down the pushrod tunnels. Not too much room there and and any excess oil on top will start to fill the valve cover. Fortunately it's an easy changeout. You just need four new rockers, a rocker shaft, and the two plugs that go into the ends of the shaft.
Bill
/ oil filter 1610TS
Hey Bill,
Thanks for the info. Do you know the torque of the rockers? Engine 2AA1
Thanks.
Randy
NC
/ oil filter 1610TS #5
Yah, I guess you mean the rocker shaft tower bolts. I'lll have to look it up in the manual and get back to you.
Bill
/ oil filter 1610TS
Hey Bill, I took the valve cover off and cranked it up.It started to fill up ,but I do not know how to tell if the rockers are worn. I guess ,I will get somebody to look at it .Thanks for all your Help, Randy Also I will let you know how it comes out Thanks again Randy N.C.
/ oil filter 1610TS #7
Randy, the rocker shaft bolt torque value is 13 lb-ft. In my case I could see oil flowing copiously from the front rocker/shaft interface. I knew that wasn't right. I confirmed the problem when I took the rocker assembly off the motor and found the rockers did not have a good precision fit on the shaft (i.e., loose). Also the underside of the shaft had wear at the front rocker location.
Bill
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
case 370 glass door never installed (A61307)
case 370 glass...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
