Oil filler cap came off...ever happen to you?
   / Oil filler cap came off...ever happen to you? #1
MuncyBob
Platinum Member
N Central PA
PT 422
Man, what a mess! Was cutting the grass last night and when parking her in the garage I noticed oil splatter on the engine cage cover. inside the cage oil everywhere! Pulled the dipstick and nothing on it. I hope I didn't do any engine damage! I have no idea how long it was running full speed with low oil level. Looks like tonight I'll be pulling the hydraulic cooler to clean out the fins(will this require bleeding the line) and may as well change the oil since I really can't make any more of a mess than is already there!
Now part of my pre ignition routine I'll be checking that cap!
   / Oil filler cap came off...ever happen to you? #2
Where my tractor is parked - in a large carport stall - was pretty level. I thought. The hydraulic oil showed a quart low on the dipstick. I added a quart and started down the driveway.
Got about 100 feet and heard a loud "POP". Stopped everything and started checking. The fill plug was gone and the hydraulic oil showed over full on the dipstick. Got my carpenters level and saw that the tractor was now sitting level.
I had overfilled and the pressure had blown the fill plug. Luckily, I found the fill plug( it's just an orange plastic plug) - removed the excess hydraulic oil with my rose gun - all was then well.
All of my 3-point was well lubed with hydraulic oil. As I remember - took four shop towels to wipe it all down. Fortunately - all the hydraulic oil created a puddle in my gravel driveway - not back on the lawn.
The plug on these engines is threaded. I guess it unscrewed itself from vibration?
   / Oil filler cap came off...ever happen to you? #4
My plugs are plastic. Transmission heat & pressure were no match for plastic threads. Perhaps it might even be considered a safety feature. If something has to blow - rather it be the fill plug than a seal somewhere. In retrospect, it must not have been a lot of pressure. It did not blow the transmission dip stick out of its hole.
   / Oil filler cap came off...ever happen to you? #5
This was your engine oil filler cap on the Robin engine?
   / Oil filler cap came off...ever happen to you? #6
I wouldn't pull the hydraulic cooler, unless you absolutely have to. Maybe spray some simple green on it and let it sit a bit?
Yes. For the life of me I cannot understand how it worked itself out. When I tighten the plug it takes a bit of force to loosen it.
Got things cleaned up yesterday. The cooler wasn't as bad as it initially looked. Used up several rags and some degreaser to get everything cleaned up. Off to get some oil today and start her up again. Based on the amount of oil I drained last night I think the wear on the engine with low oil should be minimal.
I have some oil filters that I must have labeled incorrectly. Thought they were PT oil filters but after 20 minutes of cursing when they wouldn't thread I realized the problem. Now to figure out what they belong to!
   / Oil filler cap came off...ever happen to you? #8
Oh, yes. The wrong oil filter, and it's so easy to get your hand in there and angle to just peek into see what's going wrong.
UNUSED X-STAR 70" QUICK ATTACH MANURE/SNOW PUSHER (A51247)
UNUSED X-STAR 70"...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2016 RAM 3500 HD SERVICE BODY TRUCK (A53426)
2016 RAM 3500 HD...
2021 Jeep Wrangler 4x4 SUV (A51694)
2021 Jeep Wrangler...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
