Oil & Fuel Oil Fill TC45DA
   / Oil Fill TC45DA #1
HOUNDSTOOTH
SOUTHWEST GEORGIA
2007 NH TC45DA
I just bought a TC45DA. I was reading throught the manual and stapled to the cover was a yellow print-out giving detailed instructions on adding oil. It said to remove the dip stick and very slowly add oil. It said if using a funnel, to never let the oil build up. Make sure that a steady stream runs through the funnel.
Do you know anything about this?
   / Oil Fill TC45DA #2
I've got the same tractor and if you pour to fast it just makes a mess.. thanks all..
   / Oil Fill TC45DA
I can't remember exactly, but I think it said something about oil getting somewhere that it shouldn't if you fill to much to fast. I don't get it. When the engine is running, oil is going all over the place inside. It also said to wait a min. of 5 minutes before starting the engine.
   / Oil Fill TC45DA #4
I have had fresh motor oil run out the crankcase vent tube when adding oil faster than it can run down from the top of the cylinder head to the crankcase. Newer TC's have no external crankcase vent; Gasses are vented to the intake. Pulling the dipstick helps to vent the crankcase to allow added oil to drain from the top of the head to the oilpan faster than it would with the dipstick in place.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Polaris Sportsman 500 (A51573)
Polaris Sportsman...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
