oil drain plug
   / oil drain plug #1
susieq
hunt texas
mahindra 2810
i have mahindra model 2810 i don't know where the oil drain plug is.
   / oil drain plug #3
Not being "smart" or anything, but look underneath it, on the bottom of the engine. It will have to be there on the bottom of the oil pan.
   / oil drain plug
when i looked on the bottom it has two plugs side by side so which one is it
   / oil drain plug #5
Are both on the Oil pan? If so it should not matter, but if there is any distance between them one is probly on the transmission for your Hydro fluid and one is on the OIL pan for the engine oil.
   / oil drain plug #6
If the driveshaft goes through the pan, then you will need to pull both.
Below is the oil pan on our MF 1635. See the two plugs closest to the front axle, those are the pan plugs on this tractor.
Can you take a pic for us? Then somone on here should be able to help you out.
   / oil drain plug #7
Due to the shape of your pan they both need to be removed so all of the oil can drain! Your pan is shaped like upside down U ?
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
