Oil & Fuel oil drain plug size?
/ oil drain plug size? #1
sodakbeer
LS P7030
What size hex socket (mm) do I need to remove the oil drain plug?
/ oil drain plug size? #2
Uh... take a selection down there?
I'm 58 engine hours away from my first oil change. I will find out then for the R4010.
an LS dealer called late yesterday and told me 12 mm is the correct size
/ oil drain plug size? #4
My engine drain plugs are a LOT bigger than 12mm! I am guessing at around 21mm. Actually, I think they are bigger than that! The biggest metric socket I have is 19mm and it is nowhere big enough - I use a metric adjustable wrench...:laughing:
/ oil drain plug size? #5
I think 12 mm is about right, maybe 14. I think my set was 3 different sizes and the hex is about 1/2". The plug is much bigger but it is round and only sticks out about 3/16" on the 7010 and only way to get it out is with a hex key. I had to use a breaker bar to get it loose. There is also 2 plugs to remove, one on each side of the drive shaft that runs thru the middle of the oil pan
/ oil drain plug size? #6
I am finally getting ready to do the 50 hr. maintenance on my S3010 and did a tool inventory just today. Checked to make sure I had the right socket, but didn't note the size. My service manual says they are 22mm.
The transmission/hydraulic plugs are even bigger -- 27mm. Coincidentally, that is the same size as the crank pulley nut (when you adjust the valves.)
213078 (A64276)
213078 (A64276)
2007 International 8600 Parts Truck (A63689)
2007 International...
KMC 4505 (A64126)
KMC 4505 (A64126)
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
