Oil drain plug size?
/ Oil drain plug size? #1
moship
PA
Kubota L3130 HST 4x4 Kubota L4740-3 HST
Can someone tell me what size threads the motor oil drain plugs are on L3x30 tractors?
I want to pick up a couple of seal washers prior to the next oil change. I am probably going to switch from what looks like copper washers to ones with rubber o-rings built in. Currently there is a slow drip from one of them and retorquing didn't stop it.
FYI I looked up the parts on several websites and none of them gave the thread sizes.
In case it helps anyone else the threads for the engine oil drain plugs is M12x1.25
Washer: Oil-Tite 65724
Cost: $3.99 form AutoZone for package of 2
/ Oil drain plug size? #4
Good information to know, I haven't had any leaks with mine, but now I know what to do if I do.:thumbsup:
/ Oil drain plug size? #5
Looking for the oil plug thread size for 430e or 420e Cat Backhoe.
/ Oil drain plug size? #6
uhhh.....you might try the cat forum or maybe a mod will do something..........God bless.........Dennis
GEHL RT14 SKID STEER (A65053)
GEHL RT14 SKID...
2023 Case TV380 (A62177)
2023 Case TV380...
3269 (A63117)
3269 (A63117)
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
