Oil drain plug on TN70A
   / Oil drain plug on TN70A #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
I think I found the oil drain plug on my TN70A. I will post a pic in the am. The plug looks like it needs a hex wrench. Located on side of engine block. My 10 MM wrench is too small and a 1/2 inch is too big. (Sounds like Goldilocks and the three bears??) So, any TN owners have any idea what I use to remove this plug? I assume I have the right plug.
As always, your help is appreciated.
Bob
PS My owners manual is in the mail.
   / Oil drain plug on TN70A #2
Bob my neighbor picked up a larger set of hex wrenches at Harbor Freight to pull his oil plug. Sears has them as well.
   / Oil drain plug on TN70A #3
Doc on my TN75 I used a 12mm, got it from Sears also. When you get your manual be careful on some of the fluid capacities listed, in my manual when they converted the capacities from litres, they didn't get the decimal point in the right place.
   / Oil drain plug on TN70A #4
Just about any parts store should have the hex socket you need. I bought mine from Autozone for $8-$10. It had three sizes including the 12mm the TN needs.
Coleman Go Cart (A51573)
Coleman Go Cart...
1261 (A50490)
1261 (A50490)
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
