Oil drain plug on TN70A
   / Oil drain plug on TN70A #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
I think I found the oil drain plug on my TN70A. I will post a pic in the am. The plug looks like it needs a hex wrench. Located on side of engine block. My 10 MM wrench is too small and a 1/2 inch is too big. (Sounds like Goldilocks and the three bears??) So, any TN owners have any idea what I use to remove this plug? I assume I have the right plug.
As always, your help is appreciated.
Bob
PS My owners manual is in the mail.
   / Oil drain plug on TN70A #2
Bob my neighbor picked up a larger set of hex wrenches at Harbor Freight to pull his oil plug. Sears has them as well.
   / Oil drain plug on TN70A #3
Doc on my TN75 I used a 12mm, got it from Sears also. When you get your manual be careful on some of the fluid capacities listed, in my manual when they converted the capacities from litres, they didn't get the decimal point in the right place.
   / Oil drain plug on TN70A #4
Just about any parts store should have the hex socket you need. I bought mine from Autozone for $8-$10. It had three sizes including the 12mm the TN needs.
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A53472)
NEW 2022 Load...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A52472)
2012 TEX MEX...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
