oil cooler install questions
   / oil cooler install questions #1
edkinct
NE Connecticut
CK20S HST
I got my oil cooler yesterday and will hopefully be doing the install on the weekend, but I have 2 questions.
1-I know some things have reverse threads, are the hoses that are attached to the cooler normal threads (righty tighty, lefty loosey)?
2-do I need to put anything on the threads (teflon) before I put the hoses back on?
Hopefully these questions don't make me sound to mechanically inclined.
Thanks
ED
   / oil cooler install questions #2
Ed
Depending on the model and serial number of your tractor, there may be 2 hydraulic lines and 2 adapters that are supposed to be changed with the HST oil cooler.
Other than that, all fittings are compression fittings or banjo bolt (face seal).
   / oil cooler install questions #3
From the picture posted before, he already has the two rubber hyd lines and the banjo bolts.
All are right hand threads (righty-tighty) and no sealant is needed. When you remove the banjo bolts, you'll see two rubber o-rings on each side of the metal collar on the top part of the hyd lines. One between the cooler and collar and one between the collar and banjo bolt head. Remember to use two wrenches. One on the cooler to hold steady and one on the banjo bolt to tighten. Otherwise, you'll twist the cooler like a pretzel. It doesn't need much force when tightening.
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
2020 John Deere 5065E 4 x 4 Tractor, S/N 1P45065EPLK406145, John Deere Diesel Engine, Cab, 3 Point (A59076)
2020 John Deere...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
