Oil cooler fan....
   / Oil cooler fan.... #12
I got my 425 in september of 03. When I first got it the fan worked but after using the machine for a while it seemed to get hot found the fuse where the wires comes through the hood and it was blown replaced it with a larger fuse and it ran but only intermittenly, got to checking out and it had a loose wire at the fuse fixed that and all was well.
   / Oil cooler fan.... #13
My 422 which I have had for four and one half years will run a good while before the fan kicks on in cooler weather if I am not using the mower or roto tiller. In this weather I can run it at half throddle or les for probably 30 minutes or more before the fan kicks on. Just put your hand on the oil tank and you can pretty much tell if the fan should be running or not.
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
2248 (A58376)
2248 (A58376)
2025 GPS GT612 S/A 12ft Utility Trailer (A56859)
2025 GPS GT612 S/A...
1990 LOAD KING BELLY DUMP (A58214)
1990 LOAD KING...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
