Oil cooler fan
   / Oil cooler fan #11
I was having stalling issues when warm (e.g. mowing) due to vapor lock like MR mentioned. I moved my fuel pump and lines to the other side of the engine, away from the muffler and the engine oil cooler/filter assembly on the EH72FI. I also wrapped my exhaust manifold to try to reduce the amount of heat in the tub. No more vapor lock since. :crossfingers:
   / Oil cooler fan #12
Don't want to threadjack, but has anyone found an aftermarket source for a 422/425 replacement fan? Mine is beginning to make noise, and I think the bearings will soon go out on it...
TIA!
   / Oil cooler fan #14
The one on my 1445 is a SPAL automotive fan; for the size, it is the one with the lowest power consumption, i.e. there exist two higher air flow versions. They are available at lots of auto parts stores. If you aren't looking for an exact replacement, you could try any auto parts store for a cooling fan.
All the best,
Peter
   / Oil cooler fan #15
All the best,
Peter
Just wondering what the alternatives are to calling Tazewell -- which would almost certainly be more expensive than buying locally.
Thanks!
   / Oil cooler fan #16
I was kind of surprised that there is nothing listed at Surplus Center.
   / Oil cooler fan #18
Just go to a junk yard and find a fan that is approximate.
You should save quite a bit.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
Electric Utility Cart (A56857)
Electric Utility...
LOT: Shop Tools: (2) Sets of Truck Ramps, Pittsburg Creeper, Step Stool, Road Cones, Rolling Stool (A59076)
LOT: Shop Tools...
