Oil & Fuel Oil changes for LB 1914
   / Oil changes for LB 1914 #1
hz293
Kalama,WA
Kubota B7510HSD
I've got a Kioti LB1914 with a loader. I want to change the hydraulic oil and engine oil. Under the seat there is a opening that says oil but it has no dipstick. I don't see oil in it. so here's the questions.
Is there a sight glass or dipstick to tell me if it's down?
How much oil does the hydraulic system hold and what viscosity?
I see 2 bolts under the tractor below the seat. Are these both drain holes?
Do I fill the oil through the the hole marked Oil or is there anothe spot to fill?
Any info would be appreciated.
Harris
   / Oil changes for LB 1914 #2
Sight glass for hydraulic system is on the right side of the transmission close to the brake pedals.
25.4 US Qts of Multi-grade Transmission Fluid
Most likely, but owners manual indicates 5 drain plugs.
Do I fill the oil through the the hole marked Oil or is there another spot to fill?
Yes, added to the red fill port on top of transmission.
1999 Ford Ranger Pickup Truck, VIN # 1FTZR15X6XTA79787 (A51572)
1999 Ford Ranger...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2011 GMC Sierra 4x4 Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
