Oil Change
   / Oil Change #11
</font><font color="blue" class="small">( Uh oh, do you all think I should change out of the 15-40 next time? Ck30? )</font>
You can if you want to. Nothing wrong with the 15-40 your runnning now.
The 5w-40 may be a bit better for starting in cold weather.
   / Oil Change #12
I only used the 5-40 because of the cold weather we have here in winter which is the same as Vince being that he is @ 75 miles away. You are probably fine with 15-40 you're using considering it doesn't get as cold.
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
205196 (A52706)
205196 (A52706)
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
