Oil change time - what's recommended
   / Oil change time - what's recommended #21
I use factory filters for most of my vehicles, even after the warranty's over. They usually cost about the same as aftermarket and I know that they actually meet the factory specs. I keep hearing about aftermarket filter that don't quite meet the specs for things like size of particles filtered or pressure relief valve trip point even though they're listed as compatible.......
A friend is the local dealer for Texas Refinery Corp. and a Used Oil Analysis is done on every oil change he does. Occasionally a report comes back that there's dirt in the oil and almost invariably that can be traced back to an aftermarket air filter that does not seal properly. Switch to a factory filter and the next oil change shows clean oil, as far as dirt is concerned.
   / Oil change time - what's recommended #22
For my cars I usually have someone do the oil/filter change now. Guess I'm lazy so I really don't know what I am getting as far as a brand of oil/filter. I've learned to regularly change it though.
With my tractor I do all the maintenance myself and I use the OEM (Kubota) oils and filters. This way there is far less chance of screwing up or having an issue with an inferior product.
   / Oil change time - what's recommended #23
"Most" manufacturers will state to use their fluids, but also state what "spec" that fluid is. The "spec" is industry specification. Pretty safe to go by proper spec from any leading fluid manufacturer: doing so will NOT void your warranty.
Lots of manufacturers tend to make it a lot hazier to identify what spec their hydraulic fluids are. In my Kubota I've always used Kubota's label. For my Kioti I have used what the dealer carries and uses (Mahindra): I believe, however, that Kioti does provide an industry spec. Polaris is really bad in this regard; I had to do some "reverse engineering" to track down a non-Polaris branded fluid- I used their MSDS to find a fluid that matched (turned out to not be all that big of a deal).
All of my diesel equipment is able to run the same oil, in which case the convenience factor outweighs equipment manufacturer branded oil. I run Delo 4000 LE 5w-40 or Rotella T6 5w-40: but I do so only because I have consulted the manuals for all equipment and am sure that this oil meets the requirements specified.
   / Oil change time - what's recommended #24
I use Rotella T6 5W-40
Works, Hot or cold, Plus I go 100-200hrs on a change. Thousands of hours on my machines.
   / Oil change time - what's recommended #25
Ditto on using T-6 especially in a turbo'd engine.
   / Oil change time - what's recommended #26
Another vote for T-6 oil with OEM filters. I change it every year regardless of hours. (Usually less hours than what is recommended by Kioti for an oil change.)
   / Oil change time - what's recommended #27
I use OEM filters and Rotella T6. Write the tractor hours on the filter with a marker when you change it.
   / Oil change time - what's recommended #28
They try to hide the specs to get you to use their re bottled oil. And that's all it is.you dont see a job Deere oil refinery anywhere do you ;)
Its just custom packaged, like the other brands do.
That was supposed to be OEM, not ONE. **** phone!
   / Oil change time - what's recommended #30
Come to think of it, I don't see a John Deere factory around me either :laughing:
Yeah, in most cases it's a general additive package. But, sometimes you don't really know because the manufacturer may have put some funky component in the engine that requires something special (usually to protect it). Any more, however, most will also show an industry spec in addition to their branded offering. CJ-4, which is what most have been running, is being superseded.
BobIsTheOilGuy.com
is an excellent site to read/learn about engine oils.
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
pressure washer (A55973)
pressure washer...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
