Oil Change Question
/ Oil Change Question #1
gtgrad668
I own a relatively new MF431 (<150 hours). Looking over the maintenance recommendations, MF specifies oil changes every 250 operational hours with no mention of an elapsed time frame limit between changes. I put relatively few hours on the tractor (50-100 hours/year) mostly bush-hogging. Is there any reason I should change my oil more often than the 250 hour spec? If I should change more often, what would be a reasonable time frame? If a low operational hour change results, would there be any real benefit in changing the oil filter at every oil change? Auto mfg normally specify both a mileage and elapsed time between changes, with the earliest occurring event dictating the time to change the oil.
Thanks
/ Oil Change Question #4
I am planning on doing my oil every spring no matter how many hours are on it..
Brian
/ Oil Change Question #5
I also change the filter every time I change the oil. It's very cheap insurance. When I don't have many hour on a piece of equipment I change the oil once a year.
/ Oil Change Question #6
Depending on how hard I use it during the spring and summer I changed it just before winter. Then depending on how hard during the winter I change it in the spring. With large temperature changes I think it does a number on the oil viscosity IMO. Doesn't cost much.
/ Oil Change Question #7
That's pretty excellent of MF to suggest changing every 250 hours.
In your case, if you don't end up putting that many hours on per year, I'd change the oil and filter at least once a year anyway. Some guys like to do it before Winter so the tractor sits on a fresh batch of oil to avoid any water that may have built up in the system that could cause rust or something like that. Others change in the Spring just before they start using the tractor again for the season. Just depends what flavor you like.
I change mine every 100 hours, or about twice a year.
/ Oil Change Question #8
<deleted text>
Now you are just bragging about how much seat time you get yearly to make the low hour usage ppl (like me) envious.. LOL
Brian
/ Oil Change Question #9
My Kubota manual recommends different viscosity's for my climate in summer and winter and since I use it in both I change it twice a year spring and late fall I do the filter in the spring. Not saying this is right just what I do
/ Oil Change Question #10
Oil does degrade (break down) over time, whether you're using it or not. Definitely faster if you're using it. I vote once a year too.
/ Oil Change Question #11
I thought 100 hour changes were more of the normal.
/ Oil Change Question #12
I'm in agreement with 3RRL. Change the oil before you put it away so it has clean oil with no water in it. Water is a bad thing, it reacts with the acids that build up with use. Some, change in the spring, yhat's ok, but IMHO, not as good as winterizing.
The hydraulic fluid can go 2 seasons if you don't hit the hours.
jb
Thanks to all for the advice. I think I will go with the late in the summer, once/year unless I find something more stringent from mfg.
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
Asphalt Roller Tire (A68134)
Asphalt Roller...
RIDGID AIR COMPRESSOR (A67714)
RIDGID AIR...
11.2-24 Tires - Set of 4 (A68134)
11.2-24 Tires -...
225/70R19.5 Tires - Set of 2 (A68134)
225/70R19.5 Tires...
