Oil & Fuel Oil change or not to oil change ?????
   / Oil change or not to oil change ????? #1
PUNKIN
TENNESSEE
KUBOTA L3410
Hello guys, I have a Kubota L3400. I changed the oil last fall before storing her for the winter. I have only put 30 hrs on the clock this year. The oil is dark, but it always is. Should I change the oil or let it ride? ....Your opinion would be appreciated....Thanks much in advance...
   / Oil change or not to oil change ????? #2
Last fall was a year ago!
You are way past due.
   / Oil change or not to oil change ????? #3
In a situation like that I'd probably just change it every spring, regardless of the hours.
   / Oil change or not to oil change ????? #4
Twice a year for me, no matter what.
   / Oil change or not to oil change ????? #5
100 hours or six months, whichever comes soonest for me. But it always seems to be hours for some reason... I just write the due date and hours due with a felt pen on the visible filter on my L2550.
   / Oil change or not to oil change ????? #6
I've been changing oil and filter once a year on my L3400. I normally put 50 hours in a year, but even if I didn't, that's how long I would go. I use synthetic and with that little use, once a year I think is fine. Others might disagree.
I change the hydraulic fluid and filters once every two years despite the fact that in two years I only put 100 hours on it.
In your situation, I would be changing oil in the fall before storing it for the winter.
   / Oil change or not to oil change ????? #7
What does the Kubota Owners Manual say?
I change mine every month whether I use it or not. After spending this much money for a tractor, who wants to take a chance? My grandpa and his grandpa always did and their tractors didn't tear up very often at all! I don't understand people that don't do it as often as I do!!! Why take a chance and wait over a month. I also change all my hydraulic fluids every week. Who wants to take a chance? You can't do it to often but you can sure not do it often enough!
I used my BX25 yesterday for about an hour so I also change all fluids every time I use it. Why take a chance??
What does the manual say? Maybe the Engineers at the Company will have a different idea than me and my ancesters! :laughing::laughing::laughing::laughing::laughing:
   / Oil change or not to oil change ????? #8
I go by the manual on all our tractors.
   / Oil change or not to oil change ????? #9
x2, I wouldnt want it sitting in old oil all winter, I always change oil in any motors and run for a little bit before I store them for the winter.
   / Oil change or not to oil change ????? #10
I've started using synthetic oil in mine, and will probably go more than a year before I change it. I'll probably go by the hours, which will be 15-18 months. I figure what is the point of using high quality oil if you aren't going to extend the change interval a little bit. If you are using regular oil, I'd be more likely to change by the time limit.
206320 (A57192)
206320 (A57192)
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
More info coming soon! (A55787)
More info coming...
