Oil Change help on Mahindra 6500
   / Oil Change help on Mahindra 6500 #1
RW Simmons
Shelbyville, Tennessee
Mahindra 6500
My operating manual is for a 00 series tractor and does not clearly show the engine oil fill point. Where exactly do you add/fill the engine oil on a 6500 Mahindra?
   / Oil Change help on Mahindra 6500 #2
I am not familiar with your tractor in particular, but most make it pretty obvious where to put the oil. Mine has 2 points, one is on top of the engine on the valve cover, and another point down closer to the bottom (can't remember exact placement). There should be a cap somewhere that says "engine oil" or something similar. You should really contact your dealer and get the correct manual though, it will be useful for so many other things.
   / Oil Change help on Mahindra 6500 #3
after re-reading your post, are you saying that the 6500 is not a "00" series tractor? or are you simply saying that it is not clear on where to add it?
Not clear where to add the oil! Diagram in owners manual does not look like my tractor! Thinking I might not have correct operators manual. I don't see anything that says engine oil; there is a cap to very top of block?
Teamco Bale Grinder (A50774)
Teamco Bale...
Yamaha Electric Golf Cart (A50121)
Yamaha Electric...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2003 Komatsu WA250 Articulated Wheel Loader (A50322)
2003 Komatsu WA250...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
