Oil Change help on Mahindra 6500
   / Oil Change help on Mahindra 6500 #1
RW Simmons
Shelbyville, Tennessee
Mahindra 6500
My operating manual is for a 00 series tractor and does not clearly show the engine oil fill point. Where exactly do you add/fill the engine oil on a 6500 Mahindra?
   / Oil Change help on Mahindra 6500 #2
I am not familiar with your tractor in particular, but most make it pretty obvious where to put the oil. Mine has 2 points, one is on top of the engine on the valve cover, and another point down closer to the bottom (can't remember exact placement). There should be a cap somewhere that says "engine oil" or something similar. You should really contact your dealer and get the correct manual though, it will be useful for so many other things.
   / Oil Change help on Mahindra 6500 #3
after re-reading your post, are you saying that the 6500 is not a "00" series tractor? or are you simply saying that it is not clear on where to add it?
Not clear where to add the oil! Diagram in owners manual does not look like my tractor! Thinking I might not have correct operators manual. I don't see anything that says engine oil; there is a cap to very top of block?
2005 Cat DP40KL Forklift (RUNS) (A50774)
2005 Cat DP40KL...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
Walinga Agri-Vac (A50514)
Walinga Agri-Vac...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
