Oil change for Yanmar FX32D
   / Oil change for Yanmar FX32D #1
Peterchris
Honokaa, HI
Yanmar FX32D
Is there a NAPA equivalent for the FX32D oil filter, or do I need to order a special one for the tractor? Also, what kind of oil to use?
Thanks,
Peter
   / Oil change for Yanmar FX32D #4
You may also use any brand oil, as long as it's diesel rated oil
   / Oil change for Yanmar FX32D #5
I've been using Generic WalMart 15-40 Diesel and Fram Filters for the last 7yrs. The Yanmar Dealer I bought the Tractor from gave me the # to use. There should be a book to cross reverence the Wix #.
Does anyone know the amount of oil the engine needs?
Also, since I'm in Hawaii, it never gets cold. Should I get a single viscosity oil, or just go with the 10-40 or 15-40?
I wish there were an operator's manual that showed, for example, where are all the grease fittings, maintenance requirements, etc. I ordered the reprint , but it wasn't useful. I guess there is no detailed manual in English for this tractor, so thank you to everyone on this forum!
   / Oil change for Yanmar FX32D #7
Guess around 5 quarts. Fill and watch dip stick to proper level. No oil guru but I don't think you can go wrong with the 15w40 diesel rated oil.
   / Oil change for Yanmar FX32D #8
Agreed, stick with 15W40 in Hawaii. Use a good quality oil too and change it and filter yearly.
   / Oil change for Yanmar FX32D #9
You can barely find single weight diesel oil.
I would just buy 15w40 rotella or delo or similar and change it once a year or every 18 months and call it good. dont over think it. it will be fine down to colder than you will ever get and to hotter than you will ever get.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2018 Izuzu NPR (A50120)
2018 Izuzu NPR...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
