Oil & Fuel Oil Capacity
   / Oil Capacity #1
koamfps
Michigan
NH TN70DA & NH 2120
Can anyone tell me the Oil Capacity for a TN70?
Thanks In Advance
   / Oil Capacity
Thought I would Re-Circulate this thread in hopes someone can help me out
Thanks
   / Oil Capacity #3
hmmm... Search results take you to sites with "specs" for the TN70, but they all show blank for the oil capacity?? Messicks even has a maintenance how-to showing where all the drain plugs and such are, and says "Fill oil as needed" for the oil change...
Hopefully someone with an owners manual will come forward and get the info to you...
-Neil
   / Oil Capacity #5
I had aproblem with determining the oil capacity on our'07 TD95D. The manuals (both owner's and service) says 12 quarts and hat put the oil an inch above the full line on the dip stick. I called dealer and asked what I should believe, the manual or the dipstick. After consulting with CaseNH they said the dip stick. I gave them the part number on the dipstick and they confirmed that as the correct part number. I again asked for the quantity and they again contacted CNH and they (CNH) weren't sure what the refill capacity was but they said the dipstick was correct. I pumped out oil until it agreed with the dip stick and removed 3 quarts so the refill capacity is 9 quarts rather that 12 quarts.
You'd think that some thing as important as the engine lube oil quantity would be readily known and thoroughly checked before making up a manual. Alternately they should have put out a service bulletin to correct the manuals.
I'd check with the NH dealer and get some resolution on this issue in your case.
   / Oil Capacity
That's Crazy Jerry. I will do just that! Thanks
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
