Oil & Fuel Oil and filter changes
   / Oil and filter changes #1
cdover73
Greensburg, Louisiana
2006 Mahindra 4530
I don't know why, but I had an urgent feeling that I needed to change all my fluids and filters at 100 hours. I changed the break-in engine oil and filter at 50 hours already. I now have 150 hours on my 4530 and went ahead and ordered the full filter change kit. With it bought and paid for, I figured I would buy the oil tomorrow and do a complete service Saturday. However, I just sat down with my operator's manual and looked over the frequency chart. Nothing is due until at least 250hrs, much more for the hydraulic oils.
My question is, should I be so eager to change the oils or should I just store the filters and wait? I know you can't change it too often, but am I just wasting money at this point?
Also in case I do the change, is there any concern that the hydraulics won't purge the air once I break into it? I had a friend who had a heck of a time getting his lift to work on a Farmtrac after the hose on the suction line came loose. He ended up calling a mechanic out to do a procedure to get it bled. Is it the same with Mahindras?
   / Oil and filter changes #2
Change your oil and filter....every 100 hrs after the 50 hr run-in change....Don't worry about hyd air purging...If you change it (you don't need to change the hyd fluid for about a 1000 hrs (If I remember correctly). After changing the hyd fluid/filter, operated the 3pt up/down about 10 times...same with the loader. It should purge any air that may have gotten in..Good luck with the 4530// BobG in VA
2019 FREIGHTLINER CASCADIA DAY CAB (A51222)
2019 FREIGHTLINER...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
