Oil and Antifreeze
/ Oil and Antifreeze #1
HJT
Bronze Member
SW Iowa
2007 BX2350
New member and new owner. Need to add some antifreeze to lower freeze point a little. What are folks using? Has green in it. Do you need SCA additives? I have some straight Fleetrite by International that was for my Ford Powerstroke. It is green, will it work?
Oil, manual states 10-30 or 10-40 diesel oil. CD,CE,CF,CG, I believe. Where can I find any? Most like wallmart carry 15-40. Gets down to maybe -30F sometimes here in Iowa, would prefer the 10-30. Any hometown places have it? Sorry about long post. Thanks Harry
2007 BX2350, FEL, 54" mower, Grass catcher, 42"tiller, 60" rear blade
/ Oil and Antifreeze #2
Local O'Reilly auto parts stores in middle Tennessee area carry Shell Rotella T diesel oil in 10W-30. I believe it is spec'ed CJ which is the newest diesel rating oil for the ULSD fuel systems. I run this in my New Holland TC34DA. No complaints!
/ Oil and Antifreeze #3
Your antifreeze from your Ford is not a problem. I like the Case-IH diesel oil myself for long life as I've seen the spec's and there isn't anything cheaper that has as good of specs. Kubota's fluids I feel are good as I know there equipment and would feel very comfortable with there suggestions.
I often wonder why some choose to be sure they are buying the best equipment and then scrafice in quality of the equipments life blood for a dollar or two.
Thanks guys. Yes, Art, I know what you mean. I want to run quality products in anything I own, but don't like paying what most manufacturers want for their product. For instance, motorcraft oil from a Ford dealer is almost out of site (diesel). I was using Delo 400 from wallmart in my truck. Much cheaper and used in lots of long haul trucks as is Rotella. Again, thanks guys. Harry
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
30x57 Welding Table (A65640)
30x57 Welding...
2006 Kenworth W900 Day Cab Truck, VIN # 1XKWDB9X76J112716 (A65563)
2006 Kenworth W900...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
72in. Fine Low Side Skeleton Skid Steer Bucket (A65640)
72in. Fine Low...
