Oil analysis on my Ford after 9,000 miles
   / Oil analysis on my Ford after 9,000 miles #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Numerous other discussions here but:
Ford F350 7.3L 141K + miles.
Main reason I'm pulling UOA is to establish a baseline. My Haynes manual says to change oil every 3,000 miles. My factory manual says every 5,000 miles. I changed over to Rotella T6 for better cold weather starts. With oil running about $25/gallon and my truck taking 4 gallons I'm tired of throwing away good oil, time and money.
Since I THOUGHT I was going to be changing it more often I installed a Fumota valve Fumoto Valve | Qwik Valve兌/url] which makes taking a sample real easy.
Anyways - here's what Blackstone had to say:
That oil has been in for a year and primarily gets 900 mile interstate trips.
   / Oil analysis on my Ford after 9,000 miles #2
That's fantastic!
Won't see that with any of the newer diesels that are choked up. The oil in them is black and full of soot in no time flat.
That's fantastic!
IF I pour in clean oil and run the engine for a FEW minutes the oil turns black. There's a few quarts on the Ford which doesn't get drained easily.
   / Oil analysis on my Ford after 9,000 miles #4
The HPOP and around the injector sleeves both tend to hold oil.
   / Oil analysis on my Ford after 9,000 miles #5
I use to work for a guy doing non destructive testing. He got into it because he was stationed at the Plattsburgh Air Force base and was trained by Uncle Sam. They also trained him to do oil analysis. I watched him burn samples a few times, looks pretty easy. For what ever reason he never really pushed it as part of his business. Most people just don't know the valve that a proper analysis and few try to educate them. I thought about seeing if he would train me and then sell me that portion of the business but he just stopped doing it. I always thought that with a little leg work you could have a nice source of extra income. Simply going to the local auto mechanics and highway departments would give you plenty of work.
   / Oil analysis on my Ford after 9,000 miles #6
In my 7.3 it was anywhere between 6k and 9k depending on what time of the year and how I am using it. I could go longer but I like nice clean oil in my diesels! CJ
   / Oil analysis on my Ford after 9,000 miles #7
7.3 will tell you when they need an oil change. You can hear it in the way it runs.
   / Oil analysis on my Ford after 9,000 miles #8
Wow!
That's very interesting. Thanks for taking the time to post that.
Although it was 2 years ago,......
Please verify that the test results were from RotellaT6 5w-40 FULL SYNTHETIC, that was in service for over 1 year and 9000 miles?
Your truck had 141,000 miles, does it or did it use any oil? did you have to add any over the 9000 mile/1 year period?
Are you at all particular on the fuel you use? Or do you just get what's available? do you or did you use any additives?
Wow!
Yup.
It started using oil after I put the Fumota valve in, it drips a bit and I put a pan under it, I added maybe 2 quarts before I had the oil changed.
I dropped a small tree on my back and it was too painful to be changing my oil versus having the Fulton dealer do it. when I asked how much it cost. So last summer at about 12 or 13,000 miles on that oil I had the dealer change in and they SAY they put in Mobil 1.
Not too picky on fuel. I do use Optilube.
   / Oil analysis on my Ford after 9,000 miles #10
Did Blackstone run the TBN, Oxidation and Nitration analysis on that test? You didn't mention it nor did they that you quoted. If they didn't, wear metals are only part of the story. That just says how the engine is doing in general. What of the oil itself? TBN handles acid buildup in the oil. You don't want TBN to go lower than roughly half of what it started out with. As TBN depletes, TAN (total acid number) rises. High Oxidation can lead to oil sludge building up. You really need to know that information as well to make a clear determination if the oil can be used on extended drains. You are probably ok, but there is no clear way to know without all the data. Blackstone tends to run only a very basic test. They charge for the additional testing. The better labs will include TBN and other tests as part of the package when doing diesel oils.
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
Two Post Car Lift (A50120)
Two Post Car Lift...
