OHV Adjustment 9P702 0279 F1
   / OHV Adjustment 9P702 0279 F1 #1
wolfden793
Lyndonville Vermont
Deere LX 266, John Deere Gator TX, Kubota B7500, Takeuchi TB016
Hi All,
I have a Craftsman push mower with the engine mentioned above. I'm trying to adjust the valve lash, but when I look at various videos, they all show a set screw and nut to adjust, but the mower I have does not have the set screws. Anyone else find this with their engines? Thanks for any help!
Hi Randy,
Thanks for your reply. Attached is a picture. There are no set screws; only a threaded rod with nuts attached. Not sure what to make of this, I've never seen one without them. I looked at the parts images and there is no mention of these set screws. I'm assuming you adjust by just turning the nuts in and out on the shaft? Dome scratcher!
Jim
   / OHV Adjustment 9P702 0279 F1 #4
I have come across that setup. Seem to remember they are a sort of friction fit lock nut. You turn the nut to set the clearance, but have to watch the studs because when you try to increase the gap can unscrew the stud from the head.
Yup, what you're saying makes sense. I was able to adjust the gap using these nuts, but still no compression. I removed the head and ordered a new head gasket. I guess we'll see once I get that replaced. Thanks for the link to the adjuster. I don't believe the valve cover has ever been removed so it may have come from the factory this way. Appreciate the info!
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
Genie GTH-644 (A50490)
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
