Oh joy: time to replace the bushing on my 286 Bushhog!
   / Oh joy: time to replace the bushing on my 286 Bushhog!
Glad you got them off, I have one of the fuel brushless impacts , use it all the time. I didn’t have it yet when I changed the last set of blades but I need to remove all four on my twin spindle in a few weeks to clean them up, obviously it will be the first tried. As for the blade bar nut sounds as if either the cotter key was never installed or it came out and the nut worked loose. That’s a tapered shaft on the gearbox so the nut backing off a small amount could make it wobble quite a bit, hope it’s that simple of a fix for you.
that's what has me worried that it's not gonna be a simple fix: The cotter key was installed.
So why is the blade bar so loose?
Won't really know until the 46 mm socket gets here.
   / Oh joy: time to replace the bushing on my 286 Bushhog! #22
I miss understood, thought you said the nut had backed off.
   / Oh joy: time to replace the bushing on my 286 Bushhog! #23
Did your blade bolts have keys like they are supposed to?
Glad your Fuel M18 got it off. I'm wondering how tight they were.
   / Oh joy: time to replace the bushing on my 286 Bushhog! #24
Those new battery powered impacts are amazing. My DeWalt 1/2in impact laughs at crank pulley bolts and hasn’t failed to take off any bolt I’ve tried it on yet.
Both of them do. One of them is messed up, probably the one that spun and we had to use the pipe wrench on.
2001 MACK CX613 SLEEPER (A58018)
2001 MACK CX613...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2018 Kubota U17 (A53317)
2018 Kubota U17...
Toro Sand Pro (A56859)
Rhino DB150 (A57148)
