(off)roadtrain
/ (off)roadtrain #1
Renze
Super Member
the Steernbos (Holland)
Zetor 3011, Zetor 5718
In Holland, a new trend is slowly getting liftoff: In search for more efficient means of transporting dirt, while maintaining the max legal width of which dumpers can be transported on a lowboy without special permits and guidance vehicles, a contractor in cooperation with the Volvo importer and a manufacturer of agricultural dumptrailers, have built a 5th wheel dumper on a Volvo A30 ADT with a payload of 60 ton, roughly double that of the standard A30. Volvo sells 5th wheel tractor variants of their ADT's for pipeline construction etcetera, but the idea to hook on a big dumptrailer is entirely Dutch.
Volvo A30F with BECO MAXXIM 600 trailer (payload 60T) (2) - YouTube
Because the trailer wheels are tall, they negotiate obstacles very good (angle of approach) and because they are standard section with, versus 65% section width on the ADT they allways ride in the track where the mud is already cleared by the ADT's wheels, so the trailer pulls light and the terraingoing ability is very good despite it being only 10x6 :)
Not only this A30 combination (within legal transport width limits) is in use, but also a large cement quarry has bought an A40 based combination (which DOES need a transport permit and guidance vehicle when transported on the road) with a payload of 80 ton, to replace a rigid mine truck, because the articulated ADT combination is so much cheaper to buy because it uses a mass produced A40 base unit, and can drive on existing quarry roads.
Here a video of the new combination being tested at Kijlstra, a concrete prefab factory close to the Beco dumptrailer works.
http://www.youtube.com/watch?v=t0qZzeJEpFo
/ (off)roadtrain #2
It doesn't appear to have much of an advantage over Volvo's articulated dumpers.
/ (off)roadtrain #3
/ (off)roadtrain #5
But the A40 is almost 11 ft wide...a problem if used on public roads.
Bruce
/ (off)roadtrain #7
It does appear to be an innovative machine, and have a niche market.
Curious if it would pass the Bridge Formula Law - empty.
/ (off)roadtrain
Yes, but in the case of the three A40 5th wheel dumper combinations, the lower price versus a comparable mining dumper was the decisive factor. Those mining tires alone cost a fortune. Then the truck is built in much, much smaller quantities so its also more expensive. Then later there will be more demand for a written off A40 unit than for a written off mining dumper, so better resale price.
/ (off)roadtrain
the intention isnt to use it on public roads here: in fact self propelled working machines cant have axle loads above 12 ton... The idea is that its transportable on a multi axle lowboy within legal width. That already saves a big amount of permit fees...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
Quick Attach Backing Plate (A65579)
Quick Attach...
CrustBuster 3800 Drill (A66285)
CrustBuster 3800...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
